Results 11 to 20 of 32
Thread: Marlin V 1.1 RC3
03-13-2016, 11:05 AM #11
- Nov 2014
- New Orleans
- 50
Thanks Roxy, i looked into it and appears it's been reported several times and fixed in the RCbugfix release,but I cannot get that version to compile for some reason. I think I must have missed a comment somewhere. I'll have to spend a little more time with it this week.
03-13-2016, 01:14 PM #12
Yeah... Apparently... It has been fixed for a while. And it caused a lot of bug reports when the bug got introduced:
https://github.com/MarlinFirmware/Marlin/issues/3142
I think I would download RCBugFix and verify it compiles with no changes first. And then I would start crossing my printer specific values over to it.
It should compile clean if you just download it and compile it.
03-16-2016, 10:00 PM #13
- Nov 2014
- New Orleans
- 50
Well it compiles just fine as downloaded, but when I change the motherboard to BOARD_RUMBA from the RAMPS, I get an error that I detail below. After inspection of language.h it appears that RUMBA is missing a #define DEFAULT_SOURCE_URL command. I double checked and the RC3 language.h is exactly the same, which I thought was strange. I just copied a generic #define DEFAULT_SOURCE_URL "https://github.com/MarlinFirmware/Marlin" in there and it compiled with no errors.
Arduino: 1.6.8 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from sketch\Marlin.h:20:0,
from sketch\Marlin_main.cpp:30:
sketch\Marlin_main.cpp: In function 'void gcode_M115()':
language.h:78: error: expected ')' before 'DEFAULT_SOURCE_URL'
#define SOURCE_CODE_URL DEFAULT_SOURCE_URL
sketch\Marlin_main.cpp:4351:3: note: in expansion of macro 'SERIAL_PROTOCOLPGM'
SERIAL_PROTOCOLPGM(MSG_M115_REPORT);
sketch\language.h:122:112: note: in expansion of macro 'SOURCE_CODE_URL'
#define MSG_M115_REPORT "FIRMWARE_NAME:Marlin " DETAILED_BUILD_VERSION " SOURCE_CODE_URL:" SOURCE_CODE_URL " PROTOCOL_VERSION:" PROTOCOL_VERSION " MACHINE_TYPE:" MACHINE_NAME " EXTRUDER_COUNT:" STRINGIFY(EXTRUDERS) " UUID:" MACHINE_UUID "\n"
sketch\Marlin_main.cpp:4351:22: note: in expansion of macro 'MSG_M115_REPORT'
exit status 1
03-18-2016, 08:42 PM #14
- Nov 2014
- New Orleans
- 50
I confirmed tonight the bugfix firmware does resolve the issue after adding the language.h change. Now I'm back in business!
03-19-2016, 07:42 PM #15
- 31
03-19-2016, 09:33 PM #16
03-19-2016, 09:36 PM #17
03-19-2016, 10:18 PM #18
That is cool! Do you have to do something to prime the hot end after it expands and is in position to use it?
03-20-2016, 08:54 AM #19
03-23-2016, 07:38 AM #20
- Apr 2014
- 14
Where is there any info on the retracting hot ends or is it your own design? That would be a great feature! I built an itty bitty double but couldn't get things level enough to work well, one hot end would always drag through material from the other. I removed it until I have more time to learn to set it up. Retract would be the perfect solution.
